Mitsubishi stabilisator stang stabilisatorstang
Roepnaam: Rob
Bericht door R.O.B »
http://www.30forty50.com/forum/topic/20 ... arts-help/
looking at the UR part numbers you can get a 23mm swaybar for a Proton which would fit the X40.
If you really wanted a Whiteline bar you would have to use one for a Mirage or FTO.
You can see from the pic the underside of the Proton is almost identical to the x40.
http://www.ultraracing.my/catalog/index ... er=product
Proton Gen 2 Rear Anti-roll Bar / Rear Sway Bar / Rear Stabilizer Bar
Code: UR-AR23-003
Specification: 23mm Solid with Polyurethane Bushing (Standard 12mm Solid)
http://www.30forty50.com/forum/topic/19 ... sway-bars/
Any front sway bar from 1-6 will fit the Volvo subframe, I have 25mm Cusco front sway bar on my V40.
The problems are Evo 1 sway bars attach to the lower arms/wishbone with a short droplink, so you would need to fit Evo 1 arms.
Evo 2-3 use the same droplinks as the Ph1 X40 so in theory should fit fine, only thing is I think they use exactly the same size swaybar as the X40 anyway. It is smaller than the Evo 1.
Evo 4-6 as I said will fit the subframe, but like the Evo 1 use a short droplink & attach to the lower arm not the strut.
I did try a droplink from the sway bar to the strut but the angle is too steep & hits in various places.
To use the sway bar you would need to change the lower arms, which require Evo hubs etc.
But in theory I should be able to find a thicker aftermarket evo 2-3 sway bar???
Yes, they should fit fine, I would look at FTO sway bars as well, I'm sure they run bigger front due to the heavy V6 up front.
JohanH
Roepnaam: Johan
Re: Mitsubishi stabilisator stang stabilisatorstang
Bericht door JohanH »
Klinkt allemaal leuk om een nog dikkere stang te pakken, maar je verschuift de grens dan zover dan op het moment als die gaar glijden dat de grens met omgaan wel heel erg dun is. Vandaar dat ik dat voor een straatauto niet zo snel zou aanraden. En zeker niet in combinatie met een standaard onderstel met eventueel verlagingsveren.
Des al niet te min, leuke vonst!
Ronald Rijnbout
Bericht door Ronald Rijnbout »
zijn allemaal te koop bij showoffimports in dongen
http://www.showoffimports.nl/search.php?substring=v40
ook veerpootbruggen voor 89euries
ik heb niets met dit bedrijf te maken, alleen laatst iets gekocht
Roepnaam: Rob
Even geselecteerd op Mitsubishi en stabilisator stang:
http://www.showoffimports.nl/home.php?cat=509
