Mitsubishi Rear Lower Control arm achter draagarmen
Geplaatst: vr 05 jul 2013, 21:24
Er is een Mitsubishi achterdraagarm versie verkrijgbaar voor de x40:
http://www.30forty50.com/forum/topic/19 ... trol-arms/
Mitsubishi boxed the rear arms on the Evo 2-3, they are still U shaped on my Evo 1 like the Volvo.
Mitsubishi mirage
I have those as well, they are available in blue too. You will need to get a fitting kit to attach your sway bar though.
The arms fit perfectly, I have since found Evo 3 specific arms that include the sway bar link unlike the ones in the pic above.
Helaas werkt de ebay link niet meer. Op ebay heb ik zitten zoeken en waarschijnlijk gaat het om de volgende achter draagarmen (let op het zwarte aansluitplaatje):
http://www.ebay.com/itm/DD-RACING-ALUMI ... 18&vxp=mtr
DD RACING ALUMINIUM REAR LOWER CONTROL ARM MITSUBISHI LANCER CK4A 1995-2000
PART FIT:MITSUBISHI LANCER CK4A
Nett Weight:3.8kg approx.
Condition: NEW
*ALUMINIUM.
*COLOR:GOLD
PART BRAND:DD RACING
PACKING SIZE:51.5CM X 15.5CM X 8CM
WEIGHT:3.8KG
Lower Control Arm
Ideal for street and race applications,Rear Lower Control Arms replace your stock arms while retaining factory suspension geometry.
The Rear Lower Control Arms are forged from aircraft quality AL2024 billet aluminum, precision CNC machined and are over 25% lighter than stock arms.
Lower Control Arms feature adjustable sway bar mounting holes so you can fine tune the feel and balance of the rear suspension, and also feature low deflection polyurethane bushing which act as bearings for quicker response and a more positive feel.
By allowing the arm to rotate freely about the bushing,eliminated the tearing and unseating commonly found with fixed rubber bushings.
http://www.30forty50.com/forum/topic/19 ... ntry202680
Yeah your OEM sway bar & links will line up like the originals, Evo 12&3 control arms are identical in size to the Volvo.
Only difference is they box them on the 2&3 & the outer bush is a pillowball & not a rubber bush.
The sway bar mounts on the Evo 1-3 arms are in the exact same place as the Volvo arms.
The arms will fit with no modifications at all.
I was just highlighting the fact that the OEM Evo arms didn't use a rubber bush but a pillowball & they were boxed for extra strength.
The arms you have ordered are lighter than OEM & have polyurethane bushes instead.
Aansluitend op de ebay DD RACING ALUMINIUM REAR LOWER CONTROL ARM MITSUBISHI LANCER versie, kwam ik ook deze tegen (wederom let op de zwarte aansluitplaatje voor je stabilisatorstang):
http://www.ebay.com/itm/PAIR-LOWER-CONT ... 51aa23b4dc
PAIR LOWER CONTROL ARM FOR MITSUBISHI EVO 1 2 3
Mitsubishi mirage
Condition: NEW
*ALUMINIUM.
*COLOR:GOLD
WEIGHT:3.8KG
Lower Control Arm
